Flow through 1/2\" copper
Dave_13
Member Posts: 110
I have 1/2" water lines and a well. The water pressure is always between 30 and 50 PSI. How do I figure out the flow rate??????
Flow in 1/2 inch copper tube
Flow is a function of pressure-drop, which depends on piping length and any other restrictions such as valves.
Check the Copper Tube Handbook
http://www.copper.org/tubehdbk/tables/table4.html0 -
A simple
but effective method is to just put a measured bucket under any faucet, open wide and time it.
A two gallon bucket filled by a tub in two minutes will be 1 gpm. Etc., Etc.
Thanks for the math refresher, Brian.0 -
I think you mean
a one gallon bucket filled in 30 sec's is 2 gpm :O)
Maybe we have different buckets in Swampland
Brian.
- 114 Geothermal
