Mass. smoke pipe rating
jrc2905
Member Posts: 98
Can anyone tell me what the smoke pipe gauge is in Ma. for venting a oil heat system. What is the differance for smoke pipe and warm air pipe, and how do you tell by looking at a fitting. Thanks
Smoke Pipe Gauge
Actually it should be called exhaust pipe, oil doesn't smoke if it is running right. The gauge is 26, you will often see a number 6 26, 7 26 etc. The 6 or 7 would be the diameter` the 26 is the gauge. Round pipe in duct work is, I believe 30 gauge. It is much lighter and thinner. I have seen the lighter gauge mistakenly used for exhaust and it only lasts a year or two.
Leo0 -
smoke pipe gauge
leo is correct 26 gauge for oil burning systems 30 gauge for duct work
Smoke pipe for flue gas venting must be 26 GA.in MA.
I have seen home owners buying it at home depo the problem is they do not stock 26 ga it is only 30 ga. Buyer be ware.0 -
NFPA 211 is the code
concerned here including MA.
It goes like this:
If the fluepipe is less than 6" it may be 26 gauge.
If the fluepipe is 6"-10" it must be 24 gauge.
If the fluepipe is 10"-16" it must be 22 gauge.
If the fluepipe is 16" or more it must be 16 gauge and may be welded. But, access doors must be provided.
This is a big issue getting bigger among insurance companies and a great way to get them off the hook and put you on it for not following code. As an expert I currently have three cases where heating contractors (oil co's too) will lose their cases and insurance due this oversight.
Please keep in mind that you are required to know the codes and laws in your jurisdiction and 'ignorance is no excuse', FACT!
Look at our website for current code seminars coming up this summer. www.FiredragonEnt.com0 -
George Is this in the CMR 4 Guide
I have the third edition and can't find it.
Thanks,
Leo0 -
Nope, it's in NFPA211 that
is the chimney code for all 50 states and MA too! We added pertinent data from 211 in the 4th Edition including the chart that covers this. You can order it from our website, www.FiredragonEnt.com0 -
Just to be sure
is that total length of smoke pipe? or do they take into account fittings counting for a certin amount of feet? I guess I have been venting gas units with PVC and stainless for too long.
thanks,
Chuck
Chimney code?
In N.H. we are bound by nfpa 31 I can find no reference in the R.S.A.s that refer to nfpa 211 which I believe is a chimney code.Please correct me if I am wrong.I believe we are one of the "other 50 states you refered to".?
John0 -
In NH you are bound by all of the NFPA's
since the state adopted NFPA1.
You need several NFPA's for oil including 31 and 211.0 -
Gauge of the pipe
has nothing to do with length. All of the pipe and fiitings must comform and that's for gas too!
NFPA211 covers all liquid, gaseous and solid fuels.0 -
What????
in the post above,weren't gauge of the exahust pipe, and length your point? Did I miss something?
Chuck
Hi Chuck,
nope, maybe you just got confused.
When I call out the 6" or less etc., that's a diameter.
Length is irrelevent in most calculations, except that it may not exceed more than 75% of the height of the chimney. So with a 20' chimney you may not have more than a 15' length of chimney connector (fluepipe).
Sorry if the confusion was on my part.0 -
ooooops
maybe I should have read it twice...
Chuck
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
