Air flow balancing
Kevin_10
Member Posts: 20
Is this important and why? Thanks
Balance
So one of the room is too cold while the other is too hot.....No?0 -
airflow
big ed hit it on the head you need to get even heat to all the rooms
Yes balancing the two airstreams
is VERY important. most manufactures don't bog you down with efficiency curves for their equipment, but if they did you would see that relatively small imbalances in air flow (less than 10%) cause Large Loss of efficiency(20to30%). Thats why it's also important to keep the filters clean and the cells or cores or wheels washed and clean. as a filter loads up or the transfer medium gets dirty, efficiency goes way down. Paul0
