Conversion
Dave L_4
Member Posts: 26
Does anyone have the formula for converting lbs of condensate in to btu's per hour
Thanks Dave L.
Thanks Dave L.
lbs of steam to btu's
I'm sorry I was looking for converting lbs of steam to btu's
Dave L.0 -
I think this chart is what you're looking for
I hope this helps:
Senior Designer/Trainer
Precision Hydronics Corporation
www.precisionhydronics.com0 -
Dave, only thing I find close is..........
What tom said,thank god for heating helper! John@Reliable0 -
heating values
Evaporation rate of steam is 4.15 gallons water per hr.per BHp.
Weight of 1 gal. water is 8.33 pounds X 4.15= 34.5 lbs. per hr. per BHp.
1 lb. of steam is 970 BTUH X 34.5 pph = 33,475 BTUH per BHp
Most heating professionals use 1 lb. of steam as 1000 BTUH which is much easier to estimate.
I hope this is of some use.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
