Pictures of latest radiant project
Here is a Varible Speed Injection Mixing System. It has a baseboard loop comming off of the primary loop. It is wired and running. It is a retrofit project. We installed Dale Pickards plates from Radiant Engineering. The heat transfer is incredible. Dale makes a great product! We ended up reducing the design temperature by a good amount because the plates are so good.
JR
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=96&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
