pressuretrol
JOE_24
JOE_24 Member Posts: 12
in DANS book I got steam it says if the pressuretrol pigtail is installed looking at the pressuretrol you can see through the donut this is incorrect,does anyone know what effect this will have on my heating system
  • Frank_15
    Frank_15 Member Posts: 33
    the pressuretrol will not be accurate
    When the pigtail expands the pressurtrol will not be accurate. But thats only if it is the type with mercury in it
  • If you have the type with...
    the clear front and the mercury switch, it'll rock left and right as it heats and cools, which tips the mercury at the wrong time.
    If it's the grey box snap switch type, it makes a lot less difference.
    Noel
