pressuretrol
JOE_24
Member Posts: 12
in DANS book I got steam it says if the pressuretrol pigtail is installed looking at the pressuretrol you can see through the donut this is incorrect,does anyone know what effect this will have on my heating system
the pressuretrol will not be accurate
When the pigtail expands the pressurtrol will not be accurate. But thats only if it is the type with mercury in it0 -
If you have the type with...
the clear front and the mercury switch, it'll rock left and right as it heats and cools, which tips the mercury at the wrong time.
If it's the grey box snap switch type, it makes a lot less difference.
Noel0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
