domestic waterline in concrete
Ed Wallace_2
Member Posts: 19
yes scott the pad is really 4ft thick sitting in on a granite ledge and i can pull the pipe downsize to 3/4 and add heat tape my thoughts are it will freeze once filled with water the job is in Weston Ma. not exactly gods country like Manchester by the Sea but not to bad
looked at a job today installing heat in a an apartment above a garage owners father had started remodeling job 6 yrs ago he poured a concrete pad 4 ft thick between the garage and the house he ran a 1 in copper water line inside 2in pvc where it exits the house its 3ft below grade where it enters the garage its only 12in below grade the pad was poured with the idea of building an addition onto the house now thats on hold my question is in new england will the copper line be adversly effected by the freezeing weather and cold and how to protect it ?0 -
Ed
12" below grade in NE is trouble. Once that pad ( is it really 4ft thick ? ) starts to get cold Nothing is going to warm it up.
Can you pull the copper water line and run a heat tape with it ? Heat tape and insulation is the only thing I can think of, short of running a new line. I would never allow a service to be less than 31/2 feet around here.
Can you say " last winter ".
Good Luck
Scott
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 167 Indoor-Air Quality
