How does it work?
Vettefan
Member Posts: 1
Theres a large unit outside my office that sounds like a waterfall.
Coworker says its the cooling system, and it acts like a cooling tower at a nuk plant.
How do units like this cool a building?
Why don't home use them?
The device is a cooling tower or evaporative condenser. That is where the heat absorbed by the air conditioning system is rejected.
cooling towers
Some home do use them, but on a smaller scale and the principal is the same. They call them "swamp coolers" in the southwest. Air is blowm through the water, giving off heat to the atmosphere....
In greenhouses
too for cooling; they use aspen pads in front of a fan. As water evaporates, it absorbes heat.
Farmers use it in reverse as well. I used to work on a pear orchard in Medford, OR. They turned on the overhead sprinklers when the temperatures dropped close to freezing. As the sprinkler water froze, it released heat and protected the trees from low temperatures.
cooling
the cooling tower you describe is probubly used in conjuntion with another machine/machines located inside your building the water in the tower is used to condense a refridgerant in a centrifical chiller generally some type of freon, or in the case of an absorber is condenses water vapor inside the unit, in some newer instalations [this is rare] it is used in conjuntion with heat pump system to provide/maintain a constant water loop temp which is what thease require
chris smith
porter maine0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
