geothermal heat pumps
smoore
smoore Member Posts: 28
STARTING TO GET INTO GEOTHERMALS IN IOWA AND WAS WONDERING IF SOMEONE COULD TELL ME TYPICAL COSTS FOR THESE IN NEW CONSTRUCTION AND RETROFIT. I WOULD SUB GROUND LOOP OUT SO I HAVE AN IDEA WHAT THIS RUNS. MOSTLY WATER TO AIR UNITS BUT SOME HYDRONIC UNITS AS WELL. THANKS FOR ANY INPUT.
  • Bryan_16
    Bryan_16 Member Posts: 262
    costs
    new construction will run 14k-16k depending on house and lot size. Vertical loops are more expensive, but use les yard. Good luck. What part of Iowa? Bryan
