geothermal heat pumps
smoore
Member Posts: 28
STARTING TO GET INTO GEOTHERMALS IN IOWA AND WAS WONDERING IF SOMEONE COULD TELL ME TYPICAL COSTS FOR THESE IN NEW CONSTRUCTION AND RETROFIT. I WOULD SUB GROUND LOOP OUT SO I HAVE AN IDEA WHAT THIS RUNS. MOSTLY WATER TO AIR UNITS BUT SOME HYDRONIC UNITS AS WELL. THANKS FOR ANY INPUT.
costs
new construction will run 14k-16k depending on house and lot size. Vertical loops are more expensive, but use les yard. Good luck. What part of Iowa? Bryan0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 984 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
