Steam system radiator is in the way
Kynn Jones
Member Posts: 4
I posted this in another forum (Fine Homebuilding's):
Hello! I'm getting ready to remodel my condo (an 1920s unit in New England). The building uses an old steam system, which means that I have to live with bulky radiators. Two of them are placed in such a way that they severely limit the possibilities for their rooms. I would like to replace them with something less bulky, or at least move them out of the way. It is my understanding that bulky radiators are simply inevitable with a traditional steam system. If this is the case, I guess my only alternative if I want to use steam heat is to find a way to move these radiators to less obtrusive locations (close to the windows, of course). Another alternative is to forgo the steam heating altogether, and install an electric HVAC unit (heat is included in my condo fees, and I doubt I'll be able to get out of paying it, but I may still be willing to go this route). I would love to read your comments on how best to deal with this situation.
One responder wrote back:
you can use a heat exchanger to convert steam to hot water giving lots more flexibility.
When I expressed interest and asked for clarification, the same responder wrote:
go to my dear friend Dan Holohan's website. buy his steam heating books and study them. based on your new information you will be able to make an informed decision which route to take and whether this is a DIY project or not. tell him Richard Miller sent you.
his site is www.HeatingHelp.com
So here I am. What books should I read (given that I want to complete this project in my lifetime)? Or should I accept my ignorance and hire a consultant?
Thanks!!!
Kynn
Thanks!!!
Kynn
Thanks!!!
Kynn
[ I'M SORRY!!! The subject line disappeared from my post! ]
Thanks!!!
Kynn
bulky radiators
Kynn,this site is visited by many of the very best in our industry. Go to "find a contractor" and call someone in your area to help you. There are too many variable to discuss or make suggestion in this forum, but generally, old radiators are oversized and there are alternatives. Check our www.steamradiators.com as an example. Good luck!
Kynn.....
There are lots of folks from your area posting here . Try the bar on the left marked " Find A Contractor". I bet you'll get more than a few hits , and one of them will be able to point you in the right direction . There ARE many options , but be forwarned ....in a condo association, there may be some dissent in the ranks, RE: someone who would like the same things as you , and some who won't even consider the changes because of the costs . A great contractor will be able to find a happy medium . (no promises) . Best of luck . Chris0 -
steam heat
Is this a one pipe or two pipe system.If you like steam heat and don't want to part with it I would keep the system and move the radiators.are the radiators accessable from below,basement or first floor ceiling.If you are renovating than patching a first floor ceiling would not be to troublesome.You do not want to switch to electric heat just because of two radiators.repipeing them is not a big deal.0
- 62 Biomass
