Toilet Bowl Cleaner
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
works really well on old copper fittings. Thanks to the person who suggested it here on The Wall.
We bought some "Heavy Hitter" from Grainger; it's pretty concentrated and pack a punch with 23% HCl (hydrochloric acid) so you've got to wear goggles and acid resistant gloves when you use it.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Didn't have to wait long,
either. It instantly cleaned this bucket of fittings we had laying around; I mean, as soon as you poured it on, they changed color.
Rinse well!
or they won't look like that for long
They seem to go black if you don't get the acid cleaned off well.
hot rodBob "hot rod" Rohr
That's actually
the "before" picture; it was taken in the sunlight so they look pretty good, but the fittings were unusable.
Thanks, hr; we drained off the acid and put the fittings in a bucket of fresh water to dilute and wash them clean.
All the best,
Alan
So that's how yiou guys get rich!
Re-using old copper fitings! Remind me to call you at 3AM when I get a pinhole leak in my hydronic system.0 -
No problem.
We have 24 hour service at all our locations:
Paris, Rome, Beirut, Oakland and, soon to come..........Baghdad.
can
you post a after photo? I've got a ton of new fittings that I hate to use cause they look so bad. Thanks Dave0 -
Hey Alan,
I got nothing related to your topic posted, but why can't I see you on the Wetstock III List yet? You're coming, aren't you?
Mike0 -
I thought
it was invitation only.........................:>)
Actually, I've been thinking about it, but want to make sure I can get away then.
Do what I do...
...Just show up
If not there, I am sure you'll make it to Vegas, right?
Mike0 -
MURATIC ACID/LIME SOLVE
THIS IS THE SAME STUFF THEY USE TO CLEAN TANKLESS COILS TO REMOVE CALSIUM DEPOSITS/SODIUM BICARBONATES/ LIME BUILD UP. TRUE YOU MUST FLUSH WELL WITH NEUTRALIZING WATER OR IT WILL ETCH THE COPPER AND OXYDIZE IT TO A BLACK LOOKING SURFACE. IF LEFT ON THE SURFACE WITH ENOUGH COSINTRACTION IT WILL DETERIORATE IT. IT WILL BECOME SPENT AFTER A PERIOD OF TIME. OXYGEN ONE OF THE MOST COROSIVE ELEMNTS ON THIS PLANET SO PERDICTABLE LIKE FIRE, WE CAN MANIPULATE IT OR USE IT TO OUR ADDVANTAGE.0 -
\"After\" picture
We dumped them out this morning after sitting in fresh water overnight.
The only thing that wasn't cleaned was the old flux inside some of the fittings.
thanks
for the photo,Dave0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
