Checking for leaks
Pete Novak
Pete Novak Member Posts: 23
I'm in the process of tearing up an old concrete/wood floor that appears to have some single pipe steam pipes running through. The floor and hence system has to be upwards of 80 years old, so I was thinking if the floor is out, should I change the pipes, too? Once I lay the cement, I don't want to "un-lay" it to change some pipes. Is an external inspection fine, is an inside bore scope necessary, or should I just replace them anyways? There's about forty feet of 1-1/4 pipe to replace.
  • Pete Novak
    I'm in the process of tearing up an old concrete/wood floor that appears to have one single pipe steam pipe running through. The floor and hence system has to be upwards of 80 years old, so I was thinking if the floor is out, should I change the pipes, too? Once I lay the cement, I don't want to "un-lay" it to change some pipes. Is an external inspection fine, is an inside bore scope necessary, or should I just replace them anyways? There's about forty feet of 1-1/4 pipe to replace. Thanks.
  • Pete Novak
    I'm in the process of tearing up an old concrete/wood floor that appears to have one single pipe steam pipe running through. The floor and hence system has to be upwards of 80 years old, so I was thinking if the floor is out, should I change the pipes, too? Once I lay the cement, I don't want to tear it up to change some pipes. Is an external inspection fine, is an inside bore scope necessary, or should I just replace them anyways? There's about forty feet of 1-1/4 pipe to replace. Thanks.
  • kevin_5
    kevin_5 Member Posts: 308
    > pull it out. Dan
    > _A
    > HREF="http://www.heatinghelp.com/getListed.cfm?id=
    > 174&Step=30"_To Learn More About This Contractor,
    > Click Here to Visit Their Ad in "Find A
    > Contractor"_/A_
    Pete, I would bet that 40" of pipe is the cheapest insurance you've ever bought (or sold) Kevin
  • kevin_5
    Change it!
    Pete, I would bet that 40" of pipe is the cheapest insurance you've ever bought. (or sold) Kevin
  • jeff cook
    jeff cook Member Posts: 10
    Replace them while the floor is open
    one pipe system needs to have a clear path for the condenced water to return back to the boiler. After 80 years I bet if you did look at the ID you would find at least one third of the pipe's inside wall has deposits and has heavy oydidation.
  • J.C.A._2
    J.C.A._2 Member Posts: 2
    I agree
    May as well save yourself some headaches down the line .The real reason for me would be ,why take the chance ? It's open, use the time and space to do it right .
    I've found too many lines that look fine but the goo is the only thing holding the water in . Good luck . Chris
  • Pete Novak
    consider it done
    Alright. I'm going to do it. If you can, check my latest post for the details on this project. Thanks
