Checking for leaks
Pete Novak
Member Posts: 23
I'm in the process of tearing up an old concrete/wood floor that appears to have some single pipe steam pipes running through. The floor and hence system has to be upwards of 80 years old, so I was thinking if the floor is out, should I change the pipes, too? Once I lay the cement, I don't want to "un-lay" it to change some pipes. Is an external inspection fine, is an inside bore scope necessary, or should I just replace them anyways? There's about forty feet of 1-1/4 pipe to replace.
I'm in the process of tearing up an old concrete/wood floor that appears to have one single pipe steam pipe running through. The floor and hence system has to be upwards of 80 years old, so I was thinking if the floor is out, should I change the pipes, too? Once I lay the cement, I don't want to "un-lay" it to change some pipes. Is an external inspection fine, is an inside bore scope necessary, or should I just replace them anyways? There's about forty feet of 1-1/4 pipe to replace. Thanks.
I'm in the process of tearing up an old concrete/wood floor that appears to have one single pipe steam pipe running through. The floor and hence system has to be upwards of 80 years old, so I was thinking if the floor is out, should I change the pipes, too? Once I lay the cement, I don't want to tear it up to change some pipes. Is an external inspection fine, is an inside bore scope necessary, or should I just replace them anyways? There's about forty feet of 1-1/4 pipe to replace. Thanks.0 -
If in doubt
pull it out. Dan
> pull it out. Dan
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 174&Step=30"_To Learn More About This Contractor,
> Contractor"_/A_
Pete, I would bet that 40" of pipe is the cheapest insurance you've ever bought (or sold) Kevin
Change it!
Pete, I would bet that 40" of pipe is the cheapest insurance you've ever bought. (or sold) Kevin
Replace them while the floor is open
one pipe system needs to have a clear path for the condenced water to return back to the boiler. After 80 years I bet if you did look at the ID you would find at least one third of the pipe's inside wall has deposits and has heavy oydidation.0 -
I agree
May as well save yourself some headaches down the line .The real reason for me would be ,why take the chance ? It's open, use the time and space to do it right .
I've found too many lines that look fine but the goo is the only thing holding the water in . Good luck . Chris0 -
consider it done
Alright. I'm going to do it. If you can, check my latest post for the details on this project. Thanks
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
