Total replacement of baseboard heat?
SImgarten
SImgarten Member Posts: 1
We have found a house that we would like to by south of Santa Fe, NM. However, this 2400 sq. ft. home is currently heated exclusively with baseboard heating.
Are there economical and efficient alternatives to the baseboard heat that won't drive the cost of the house beyond it's market value? If so, how much of an effort is it to implement the alternative?
Thanks........
  • bigugh_4
    bigugh_4 Member Posts: 405
    Reasons for keeping BB heat!
    !. Drafts. BB heat is usually draftless. that is the air currents are much slower than forced hot air. 2. BB should be a lot more quiet. 3. Usually the temperture difference between the floor and the cieling is much smaller that forced air. 5. BB requiers small pipe as Forced hot air needs large ducts. Inshort, BB heat is more totally comfortable than forced air. Drawbacks? A/C is and must be a seperate consideration. Forced air can handle both, where usually BB is heating only. Installation & design of either job is almost more important that the heat type itself, except for the above advantages of BB heat
  • Joe_13
    Joe_13 Member Posts: 201
    I'm shaking my head
    You want to remove the best type of heating there is?????
    Spend the labor dollars you were going to spend removing the BB on a better boiler, air eliminator, etc. If you're gonna spend dollars on ductwork for AC, then think about how you'll be able to place the vents in the best location for cooling not for heating. You can get one of those new high velocity AC handlers and use the small tubing ducts and small air vents that look like mini halogen cans, almost invisible. Be happy you have hydronic heating.
  • Jed_2
    Jed_2 Member Posts: 781
    And then there is.....
    Ductless tri-zones. Increased cost of equipment will probably offset cost of ductwork, and can be installed in a day or so. No brainer.
    Jed
  • Dan Peel
    Dan Peel Member Posts: 431
    what type baseboard?
    Is this an electric or a hot water baseboard system? Dan
  • heatboy
    heatboy Member Posts: 1,468
    If your baseboard is hydronic (water).....
    Take a look at some flat panel radiators. Vasco, Myson and Runtal are three manufacturers that offer these. Asthetically pleasing, sturdy and available in a multitude of colors are some reasons to check them out. Also, adding reset technology to your system will increase the radiant affect of the panels. Quiet and efficient.
    Fin tube baseboard, while inexpensive, is not my first choice in heat emitters.
    hb
    Runtal Low Profile Baseboard
  • Richard Miller_2
    Richard Miller_2 Member Posts: 139
    Tell us more
    What knd of baseboard is this? Electric or Hot Water? Why don't you like it?
    If you call my dad, Allen Miller, he may be able to help you. He is in Belen but gets up that way quite a bit. He has been doing this since he was 18 years old. Number is 505-861-0661 but don't call him on Sunday.
  • kevin
    kevin Member Posts: 420
    if its..
    hot water baseboard you could add a outdoor reset control to the boiler and that will be a big improvement...kpc
