Paint removal
kevin
Member Posts: 420
who is marketing a newer style of sand blasting using dry ice as a medium....no sand cleanup and works well kpc
I have
several items made of steel & some made of cast iron that I would like to remove the old paint and rust and then repaint. Some are tools like my old digging bar (covered in rust( and an old antique 2" flo check valve and such stuff I would just like to use as decorations. What are some good methods? Would sandblasting work? Any suggestions on the paint?
there was on
the Piers, a way to remove rust with a battery charger and some washing soda. It actually replaces the oxygen in the rust there fore not damaging the item, as sand blassting would do. bigugh A good paint remover could be used if painted0 -
Blast em
if they are fragile or soft parts the blaster can use a softer media. My blaster dude used walnut shell husks to blast aluminum or plastic parts. Blasting is cheap, easy, and safe.
hot rodBob "hot rod" Rohr
better have lots of ventilation
That's alot of CO2 to dump into an area. Human breathing is driven by CO2, and too much in the air makes you stop. It's also a good bit heavier that air, so when you pass out you end up in a higher CO2 area.
If someone were to do a bunch of this in a smaller room with insufficient ventilation, it could be really bad. This was a major problem with CO2 fire supression systems to the point where they have been banned in computer rooms.
Can you tell I'm a geek and a scuba diver?
jerry0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
