venting problem
jim f
jim f Member Posts: 182
i ran into a situation today where the customer wanted an estimate on replacing a old williamson furnace. well, the williamson had a rear flue that came off the back of the unit near the floor.....the chiminey where it terminated(the thimble) was maybe 18" off the floor. how would you vent a modern furnace in this scenierio. inline draft inducer would be my guess. any ideas??
jim f.
tri-city heating and cooling
  • TGO_11
    TGO_11 Member Posts: 1
    vent
    Why not just cut a thimble into the chimney at the proper height? Be sure to check the chimney height and size requirements for the new unit. Good Luck
  • john_14
    john_14 Member Posts: 2
    inducer
    just a thought on this: if your trying to vent down what would happen when the burner shut off? I have seen this on much less drop than you would have here and the results are not good. I would recommend going into the chimney at the proper height. if you dont I would recommend an extended post purge to vent the exhaust gasses out of the unit.
  • John@Reliable_2
    John@Reliable_2 Member Posts: 104
    Time for a hammer!
    John@Reliable
  • jim f
    i wish i took a picture but the thimble goes into a corner on a 45 and from what i can gather goes through foundation wall i would have to guess about 3 ft before it hits the tiled chimney
  • Joe_13
    Joe_13 Member Posts: 201
    horizontal unit
    What about the units designed to be rafter hung? The Lo-boy design would allow you to base it off the floor and pitch the vent right out. I don't think you'll find many over 100K BTU. low 80's AFUE is the best you'll probably find in these units.
  • kevin
    kevin Member Posts: 420
    that's
    going to be a REAL BIg hammer!
