connection of b-vent to single wall chimney liner
John Kirchner
Member Posts: 2
Is there an approved (listed) connector to connect b-vent to a flexable chimney liner ? If so what companies make this product? thank you, John
Why?
are you using B-vent to connect to a chimney?
Jed0 -
Liner connection
I am not sure what is available in your area but where I live (Winnipeg,Canada) there is a local manufacturer of b-vent. They make a connector for that end which is crimped and fits inside the flex liner and gets screwed on.Whoever makes b-vent for your local supplier should have a fitting available.0 -
Any of the following
manufacturers of chimney liners:
Tru-Flex Metal Hose Corp. 800-255-6291
Saf-T Vent from heat Fab Corp 800-772-0739
Z-Flex 800-654-5600
Dura-Vent 800-227-8446
Also your local Metalbestoes or Hart Cooley sales rep could help you.0 -
Jed, look in the venting tables in NFPA 54
B-vent allows for a wider range of inputs allowed, when used as a vent connector.
Noel0 -
Thanks, Noel
Hadn't looked at it that way.
Jed0
- 167 Indoor-Air Quality
