connection of b-vent to single wall chimney liner
Is there an approved (listed) connector to connect b-vent to a flexable chimney liner ? If so what companies make this product? thank you, John
  • Jed_2
    Jed_2 Member Posts: 781
    Why?
    are you using B-vent to connect to a chimney?
    Jed
  • Don_4
    Don_4 Member Posts: 41
    Liner connection
    I am not sure what is available in your area but where I live (Winnipeg,Canada) there is a local manufacturer of b-vent. They make a connector for that end which is crimped and fits inside the flex liner and gets screwed on.Whoever makes b-vent for your local supplier should have a fitting available.
  • Any of the following
    manufacturers of chimney liners:
    Tru-Flex Metal Hose Corp. 800-255-6291
    Saf-T Vent from heat Fab Corp 800-772-0739
    Z-Flex 800-654-5600
    Dura-Vent 800-227-8446
    Also your local Metalbestoes or Hart Cooley sales rep could help you.
  • Jed, look in the venting tables in NFPA 54
    B-vent allows for a wider range of inputs allowed, when used as a vent connector.
    Noel
  • Jed_2
    Thanks, Noel
    Hadn't looked at it that way.
    Jed
