Vertical pipe supports
Wayco Wayne
Member Posts: 615
a Buderus Radiator. The Wall behind it is 1/2 drywall over a 1/2 inch air space over brick. There is not enough space behind the wall to run the water lines. I must run the water lines from a bulkhead above the wall down the front of the wall, to the right side of the radiator. I am using 1/2 inch copper. What's the best way to support the vertical copper and still have it look nice.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hmmmmm
maybe copper split ring on threaded rod into a lead shield anchor.
HHMMMmmmmmmmmm.0 -
Noel is correct
there is avaliable double expansion devices that hold great in brick and motar. Thing is to drill that stuff without "Hammering" just use a carbide tipped drill. I'd use the 1/4-20 in bolt size drill two holes and use a 1/2 ' copper riser clamp to hold it. You could cut off the riser calmps long legs and just yset the bolts.
Anyway
bigugh0 -
How about .....
Van Hangers. At least thats what we call them here. Its like a split ring / two hole strap cross, at the pipe but has "bell housing" that acts as spacer and support. "Copper clad" construction. Comes wilth a long copper screw that you would use in to the gyp board.
Makes a nice looking job.
p0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
