who makes waxless gasket for toilet for radiant
ken_6
Member Posts: 33
Fluidmaster
Even if I don't do the plumbing I supply these and require the plumber to use them. Impresses the HO. If this is the case the plumber is usually in the dark ages and it pisses him off. But the HO will stand for me.0 -
Zurn has a new product with two rubber seals and a small length of pvc pipe called the Flo-Bowl Jr. I have asked our local Zurn rep-my competitor-for information, as we too have lots of calls wondering what to use around the water closet.
Supply House Times March 2003 edition has an advertisement on page 52, that will give you some detail. Looks interesting.0 -
The original
waxless toilet connector was invented by Bob Adjoran. You can order direct at 1-800-323-6188. They cost about $8 and are re-usable. It works well. If you want to read about it, you could do a search on Julius Ballanco's column in PM Magazine, which is where I found out about it.
Jim0 -
Sponge rubber bowl gaskets
Kirkhill mfg. and Wolverine Brass Works both still offer sponge rubber bowl gaskets in differing thicknesses. sorry I don't have ph. no's.Kirkhill from some wholesalers and Wolverine from their Reps.0 -
rubber gaskets
Hate to say this but I've seen the Fluidmaster type at the orange palace.0 -
I call it the "H" place. I buy it from my wholesaler. I like Fluidmaster's product better than all the others I have tried.0
