Oil Tank Question
Jim_24
Member Posts: 1
I am having a problem with my underground oil tank. It seems out of no where the vaccuum on my oil pump is close to 20 inches. I had no heat a few days ago and then a couple of service calls later a serviceman said that I have a bad foot vavle in the oil tank. The tank is about 40 years old, I have 2 lines 1/2 in copper to the burner a shut off vavle and the serviceman cleared the line and checked the vavle to see if it was clear. He changed the pump from an A pump to a B pump. But it makes a lot of noise. I was told that the foot vavle is bad. My question is what does a foot vavle do,and how can I fix this with out digging up the tank to expose the lines?
oiltechtalk.com
is where you should post this question.0 -
Honest?
My feeling is to do yourself a favor, and find a place for a tank above ground.In the long run, it's going to cost almost as much to get to the "footvalve" by digging it up, and repairing, as it would to replace the tank,unless it's huge.(if there is a footvalve, it will have to be dug up and capped or plugged)
If it is a big tank, think about the future. Banks in my area won't write a mortage for a house with an "in ground" tank now. This thought is spreading in the insurance industry like wild fire.
I like oil heat , and still think it's the best in the cost /BTU vs. most fuels . An underground tank can be a liability and if you ever want to sell your home, now is the time to rid yourself of it. It may cost some now, but as far as I can see, it ain't gonna get any cheaper.JMHO Chris0 -
A foot valve
is a check valve in the bottom of your tank on the supply line. Gotta dig it up and replace, or try using return line into tiger loop. This will work if the return line goes to the bottom of the tank. You would then have one supply line from the tank.
oil tank
Also if you are in New York, there is currently a NYS income tax credit of $500, which applies to the the replacement of your tank. This is good atleast untill the end of this year, but they may extend it. If it were me I would consider a new tank anyway, what else do you have thats 40years old and still in working order?0 -
Foot Valve
Foot valves are a one way valve installed in the tank on the supply line . They were used pre WW2 with the use of wall pumps to prevent the siphon back of the oil to help keep the pumps primed . Wall tanks were used with gravity feed oil burners like a Timkin . If the oil line comming in the basement are made of iron you could very well have a footvalve...
My guess by the age of your home , the copper lines and what you describe ,you have a inline check valve that went bad. Look for a hexogon coulpling along the supply line and remove it .And yes if it's not inside you need to dig up the lines. I have found them out side on top of the tank as well .The spring rots out and the ball bearing could slide back and forth causing the exact condition you have decribed...So hurry up and start digging before the ground frost arrives...0 -
Throwing good money after bad
get rid of the underground tank. I totally agree with other posters on this. At 40 yrs old you cannot say the clock is ticking. The clock HAS ticked!0 -
IN GROUND OIL TANKS
IF YOU ARE ANYWHERE NEAR A WETLAND (AND IN SOME CASES NOT) DO YOURSELF A FAVOR AND LOSE THE UNDER GROUND TANK. IF THAT TANK EVER LEAKS AND IT IS FOUND TO BE DOING SO YOU ARE IN FOR SOME HEFTY CLEANUP COSTS AND FINES (this could include soil replacement in the hundreds of cubic yards).SINCERLY JOHN PITCHER HEART HEATING0 -
tank
Look into a Roth oil tank .Small foot print ,insurance against leakS ,double wall nice product installed one last month0
- 167 Indoor-Air Quality
