odd tingling
kk_2
Member Posts: 57
Man, another homeowner sucking on tinfoil covered walnuts without consulting a professional. When will they learn?
I recommend that you seek professional help immediately!
whenever i am
sucking on a walnut wraped in tinfoil and touch the reset button on the stack control while hanging onto the watts prv, i get an odd tingling in my toes. what's wrong with that prv?0 -
You need...
di-electric socks! In lieu of di-electric socks, you could use yellow brass slippers and avoid the same situation. Also, if you used lead foil instead of aluminum foil, the electrolytic charge would be reversed, and the tingling would be in your lips!
Maytell you better call in a pro.
Duncan! Can you help this person out?
ME0 -
I recommend that you seek professional help immediately!0 -
Stray capacitance
I agree, call in the pros... This one might better be handled by Dr. Science.
But I do have a question for c-rex.
If you suspend yourself from the ceiling with an insulator like braided rubber bands or bungee cords, so your feet are not touching the floor while you're pressing the reset, do you still get the tingling?
If you do, try re-positioning the rubber bands around your neck. The tingling will eventually stop.0 -
I KNEW we could depend...
on the King of Tin Foil hats to come through with a good suggestion.:-)
ME0 -
and
I, for one, have sorely missed your delightful sense of humor Duncan. Da pace ain't da same wid out cha.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
