Speaking of oversized boiler
I am currently giving a proposal on a job with pipes with no insulation. Homeowner says they will insulate pipes. Do you think it will be a big deal if they do? I figure a little oversized is better than under. And if I get the air out quick all should be good.
Anyone agree or disagree?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=280&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    how over is over....
  • nick z.
    nick z. Member Posts: 157
    Steam or water?
    If its Steam Iwouldn't do the job without insulating the pipes.Water, the heat loss and pick-up shouldn't change from the pipes being insualted or not.
