Speaking of oversized boiler
Paul Mitchell
Member Posts: 266
I am currently giving a proposal on a job with pipes with no insulation. Homeowner says they will insulate pipes. Do you think it will be a big deal if they do? I figure a little oversized is better than under. And if I get the air out quick all should be good.
Anyone agree or disagree?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=280&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
how over is over....
Steam or water?
If its Steam Iwouldn't do the job without insulating the pipes.Water, the heat loss and pick-up shouldn't change from the pipes being insualted or not.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
