pressuretrol problem?
Steven_2
Member Posts: 2
You were absolutely correct. Thank you. The pig tail was completely obstructed. Not even a breeze of air would pass when using compressed air on one end. It took about an hour of coat hanger work, hammer and propane torch to clear it out. I do not understand how the system could have been woring at all. Many thanks again,
Steven
Steven
My oil burner does not repond for a call for heat unless I raise the cut-in setting to above 1 psi (it is set at 0.5 psi) or raise the differential from 1 (where it is now set) to 5. Once the burner kicks on, I then readjust either setting back to baseline (the burner keeps running). Does this mean tht the pressuretrol needs replacing or could it be telling me something. (its a one pipe steam system if that is relevant)
Thanks much for any info0 -
Check the pigtail pipe under the pressuretrol. Sounds like it's plugged. It will let pressure build and trip the switch but acts like a check valve and won't let the pressure back out. Pull it apart and clean it. If it's steel pipe, replace it with a brass one....
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 50 Biomass
- 74 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 853 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
