Using Cooking Oil as Medium
Terry
Member Posts: 186
type used is corn-oil (thanks for helping out)
Terry
Terry
Heating Cooking Oil
I have been asked to size a heat exchanger for a honey farm which requires cooking oil circulated and maintained at 103F-105F during operation (50F-105F on startup).
NO idea of thermal properties of cooking oil. Only that the specific gravity is 0.9212-0.9250 @ 60F. Oil Flow rate will be 4.16GPM
Any ideas or links that may help? or have any of you had the opportunity to try this?
thanks in advance
Terry
Cooking Oils
Will try to search out some things later but, believe you should specify the EXACT TYPE OF OIL TO BE USED--particularly given the very tight temperature control required.
I know from cooking that corn, soybean, safflower, sunflower, olive, sesame, etc., etc., etc., oils seem to have great variance in their viscosities (particularly at different temperatures) and seem to heat at different speeds (differing specific heats?). Hydrogenation greatly affects viscosity as well I believe.0 -
Some possible links:
No time right now to research them thoroughly.
http://my.engr.ucdavis.edu/~rpsingh/IFT/spheat.html
http://www.engr.usask.ca/classes/ABE/323/notes/specificheat1.pdf
http://acta.chem-soc.si/45/45-1-69.pdf
http://www.vicanpump.com/engineering_data/content_typical_and_approximate_viscosity_list.htm
