Modified Danfoss - DF
heatboy
Member Posts: 1,468
Could you e-mail me the specifics about that mini-tube panel? I don't quite follow how it works.
hb
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=103&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hb
ZCP Panels
Here are some Danfoss panels we modified for a large snowmelt/pool/spa heat application. We added a tekmar 661/091 snow sensor and control to operate the three snowmelt zones. The smaller ZCP on the bottom left is a modified mini-tube injection panel devised by Robert Bean. Rather than vary the flow rate (a la variable speed pump), the flow rate through the mini-tube injection bridge remains constant while the temperature modulates via a four way motorized valve. The sensor is on the snowmelt manifold 90 feet away. The system worked great during the 2+ foot snowstorm we received several weeks ago.
We added a Triangle Tube heat exchanger to heat a fish pond. Actually it keeps it from freezing with a setpoint of 41*F.
Two Burnham Evolution boilers supply the four Danfoss panels.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
how cool
is that!0 -
Beatiful work Dan
The stuff you do boggles my mind. Very impressive WW
I can't find
anything to criticize; it's perfect.
Well, maybe that pond has a few too many leaves in it. :>)
Awesome work, Dan!
- 167 Indoor-Air Quality
