Toe-kick heaters
g.s. johnson
Member Posts: 1
Can a hot water toe-kick heater such as a Myson or Beacon-Morris unit work with a cast-iron radiator system in a residence?
I would
put it on its own zone.Retired and loving it.0 -
is it steam or hot water
the only way it will work easily is if its a hot water system, and there has to be a circulating pump on the system. It can't be gravity circulation0
