Toe-kick heaters
Can a hot water toe-kick heater such as a Myson or Beacon-Morris unit work with a cast-iron radiator system in a residence?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    I would
    put it on its own zone.
    Retired and loving it.
  • steve_6
    steve_6 Member Posts: 243
    is it steam or hot water
    the only way it will work easily is if its a hot water system, and there has to be a circulating pump on the system. It can't be gravity circulation
