CODE Question - boiler distance to tank
Steamhead
Steamhead Member Posts: 18,178
but one of my books says they should be no closer than 5 feet and another says 7 feet, and more distance is better than less. It's best to check to see what code is in force in your area, and what that code requires.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
  • David Van Wickler_3
    David Van Wickler_3 Member Posts: 63
    Distance between
    I need to move my boiler close to the tank. Can I do this (under 2 feet)? And what fireproofing do I need? Could someone fax me the code?
    631 471 4950
    Thanks a bunch
    DVW
    NY State
    I framed the oil tank and put 3/4" sheetrock over the frame.
  • October Home
    October Home Member Posts: 75
    I'm always willing to ask the question which shows my ignorance in the hope that someday I won't be so ignorant: What precicely is the reason for the 5-7 feet? How much of a fire danger is there for a closer tank?
    Arlene
  • kevin
    kevin Member Posts: 420
    i believe NFPA 31....
    says 5 feet...that is usually the # everyone uses. I am sure insurance companies have done a ton of studies to figure this out. I wouldn't be real comfortable with less than this. just think 2-3 feet from a leak that could spell disaster. kpc
  • Dave Palmer
    Dave Palmer Member Posts: 186
    code
    is no less then 5 feet. I looked at a job not to long ago where the new homeowners could not get insurance on their home because the morons who installed the replacement boiler to close to the tank.We installed a new tank(no way were we going to move a 40 yr old tank) across the room.
  • Dave Palmer
    code
    is 5 feet or a vaulted tank.We did a job where the new owners could not get insurance because the replacement boiler was to close to the tank (not by us).We installed a new tank across the room. If a tank leaked or a boiler malfunction accurred the thinking is you would smell or see it before a accident could happen.Dave
  • Keith_3
    Keith_3 Member Posts: 12
    Oil tank separation
    Section M2201.2.1, 2000 International Residential Code says,"Supply tanks larger than 10 gallons (38L) shall be placed not less than 5 feet (1524 mm) from any fire or flame either within or external to any fuel-burning appliance." Hope this helps.
    Keith
  • Rich
    Rich Member Posts: 20
    Code
    The code in my area allows you to build a fire wall.This can get you as close as you've specified.
  • Jerry
    Jerry Member Posts: 9
    My inspector says 5' or you need a 4" block wall between them.
  • Glenn Harrison
    Glenn Harrison Member Posts: 405
    Is that the name of the book,
    "2000 International Residential Code", Keith?
    I think I want a copy of that book, since residential is what I do.
    Thanks,
    Glenn Harrison, Residential Service Techician
    Althoff Industries, Crystal Lake, Illinois
    Althoff Industies Link
