Werks in Progress-PGP
Paul Pollets_2
Member Posts: 63
Just finished the near-boiler piping on a project on Vashon Island, near Seattle. It's nice to get out of the city (by Ferry) and disappear into the country. The system will heat the residence with RFH and 3 Towel Bar Rads, the deck around the indoor lap pool, the pool itself, with a FPHX and the Garage guest rooms with 3 Wall Panel Rads. The mechanical room is in the garage and we used Ecoflex underground distribution for all the heating mains and potable water. The Vitola 200 boiler will use a Riello burner until the new "Blue Flame" chassis burners are shipped. Also used a Vitocell 300-79g DHW tank and the Vitotronic 200 computer. We'll also do the pool dehumidification with a Lifebreath 200 MAX.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Nice, Paul!
Another burner change. Just when I start to get the hang of the Chassis burner............. What size boiler is that and where will the pool mechanicals be?
I wish someone around here carried Ecoflex. It would save quite a bit of time. Where do you get those cool unistrut end caps?
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
details
Ecoflex is now stocked in smaller pieces around the country so wholesalers can make room for it. Try my friend Larry Ackelson lackelson@ecoflexna.com for the answer. The strut end caps are from B-Line, The pool mechanicals will be next to the lap pool, about 90ft from the garage. The Vitola is a #33.
Hope you're well...see ya at HCT!
Paul
end caps
I think unistrut makes them, too.
http://www.unistrut.com/pdf/General_14/S02_channel.pdf
pdf page 40, catalog page 60
Mark0
- 167 Indoor-Air Quality
