P H test help
LEAD PIPE
Member Posts: 199
I just got around to testing the water in the system for the ultra boiler. The manual says the ph should be between 7 and 8.5. mine is just about 6. What do I need to do and how do I do it? I'm a wethead noob so please be specific.
thanks for the help
thanks for the help
You need to add a little
baking soda. Baking soda is a 9 Ph, so if it's a 4 section or less, I throw in a pound. Mix it with water first and it gets easy.0 -
never
would have thought about baking soda!!!
what do you use to bring the level down???
my guess would be vinegar or something similar. what if you are using glycol in your system?
Chris
That's an aluminum
heat exchanger. You need to be real careful with water treatment, as you noted it has a tight tolerance. Are you saying you drinking water runs a ph of 6?
I think I would be sure to flush and clean that system first. It could be residual solder flux or something throwing that ph to that range.
After a good clean and flush, again test the fluid. Considering the cost of that boiler I would consider a good hydronic treatment conditioner. A good treatment will buffer the ph, scavange any O2, and most importantly for that HX, it will offer a film provider to coat and protect the aluminum from any attacks. This way you assure good heat transfer from the burner to the fluid. Even a tiny amount of scale or hardness build up throws the low mass, small passage HXs for a loop.
The latest batch of condensing boilers, regardless of the brand, will need more waterside care than the ole cast iron appliances we are used to. Check with the manufactures for cleaning and warranty requirements!
hot rod
modern water tretment for these new hitech components
Our two new products were specifically design for these applications (cleaning and prevention). Go to our web site www.rhomarwater.com and look under hydronic category. The 9100 cleans the system and the 922 safeguards against the various chemistries that can happen due to the different metals etc. Like Hotrod said, these new systems are much more complicated in their water treatment. Like many areas in our lives, technology has its gifts and the need to respond in a new way.0 -
yes
I just tested the drinking water and it was a 6 also. Where can I get this conditioner you mention and will it bring up the ph?0 -
see my post under modern treatment of water
My post will give you some input.0 -
pH 6
Do you get copper stains in your tub and such?
pH of 6 is hard on the pipes and most water heaters.
Consider an alkaline injection system.
Most use Soda ash, also known as sodium carbonate (CNa2O3).
Do you have a well? That would be unusual for a municipal water supply.0 -
nope
No no water staining of any kind, maybe the strips were wrong is there a more advanced test that can be done?0 -
I can't wait to get mine
It was a pleasure talking with you the other day George.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
