SLANT FIN TUBING
Bill Riordan_3
Member Posts: 31
Does anyone know if Slantfin Terra-Therma 1/2 PEX tubing can be connected to Wirsbo manifolds using Wirsbo compression fittings? Thanks in advance.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=274&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Slant/Fin Tubing
If the Wirsbo manifold compression fitting has a split ring, it should work fine. Any pex A, B, or C tube that meets the ASTM F876/877 standards should be interchangeable ... I've used Slant/Fin manifolds, both modular and copper (Dahl valves) with Wirsbo, RTI, HeatLink ... you get the idea.0 -
Thanks
Thanks, just wanted a second opinion.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 120 Geothermal
