thermometers
johny
Member Posts: 19
What type dial thermometers do you guys use on hot water lines.Want to install into T on 3/4 in. and 1&1/4 inch lines.The shortest stem thermometer i can find is 2&1/2 inch long.Want to use least amount of fittings connected to T and then install thermometer which has 1/4 inch NPT connection.Thanks.
We use
a dial type of strap on thermometer. No well. Straps on to the outside of the pipe.
ME0 -
Thanks
Mark I greatly appreciate it.0 -
A couple more options
This Taylor brand is a small battery powered thermometer, available from Graingers. Very accurate when used on copper or steel pipes. It comes with about 20 feet of lead for remote mounting. The battery seem to last a few years
For pex lines, a well type with the probe into the fluid is much better. I haven't seen any 1/4" thermometers, although you can find 1/4" tridactors (Laars uses them on their boilers) I'm not real impressed with the accuracy of the temperature function, however.
This is a 2-1/2" well I use with Trerice brand temperature gauges. Generallt a tee with a close nipple and FIP adapter put one into a copper line.
hot rod
Dial thermometers?
I use the Pasco thermometers with a 3/4" sweat in well They are also availale in 1/2" ips model 1450 3/4" sweat model 1449 1/2" ips
John0 -
dial thermometers
Honeywell/Braukmann makes dial thermometers with choice of 2" or 2.5" dial, 1/2" ntp or sweat wells
Mark0 -
strap on thermometers
Dear Mark! Would you please share the information about strap on thermometers: manufacturer,manual,description.
I couldn't find them in any catalog.0
- 86.8K THE MAIN WALL
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
