thermometers
johny
johny Member Posts: 19
What type dial thermometers do you guys use on hot water lines.Want to install into T on 3/4 in. and 1&1/4 inch lines.The shortest stem thermometer i can find is 2&1/2 inch long.Want to use least amount of fittings connected to T and then install thermometer which has 1/4 inch NPT connection.Thanks.
  • We use
    a dial type of strap on thermometer. No well. Straps on to the outside of the pipe.
    ME
  • leroy
    leroy Member Posts: 6
    Thanks
    Mark I greatly appreciate it.
    hot_rod Member Posts: 24,938
    A couple more options
    This Taylor brand is a small battery powered thermometer, available from Graingers. Very accurate when used on copper or steel pipes. It comes with about 20 feet of lead for remote mounting. The battery seem to last a few years
    For pex lines, a well type with the probe into the fluid is much better. I haven't seen any 1/4" thermometers, although you can find 1/4" tridactors (Laars uses them on their boilers) I'm not real impressed with the accuracy of the temperature function, however.
    This is a 2-1/2" well I use with Trerice brand temperature gauges. Generallt a tee with a close nipple and FIP adapter put one into a copper line.
    hot rod
  • John Abbott
    John Abbott Member Posts: 358
    Dial thermometers?
    I use the Pasco thermometers with a 3/4" sweat in well They are also availale in 1/2" ips model 1450 3/4" sweat model 1449 1/2" ips
    John
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    dial thermometers
    Honeywell/Braukmann makes dial thermometers with choice of 2" or 2.5" dial, 1/2" ntp or sweat wells
    Mark
  • Mad Russian
    Mad Russian Member Posts: 29
    strap on thermometers
    Dear Mark! Would you please share the information about strap on thermometers: manufacturer,manual,description.
    I couldn't find them in any catalog.
