Adding radiant heat to existing steam system
Bob Gagnon plumbing and heating
Member Posts: 1,373
injectin pumping with cont. circ. bob
I own a 100 year old house with a one-pipe steam system and large cast iron radiators. My hot water is heated off the boiler and stored in Thermo 40 gallon tank. We are about to add a 2 story, 1000 sf addition, and I would like to put in-floor radiant heating. Can I use my existing boiler/water heater or do I need a separate system for the addition? I really want to do whatever makes the most sense.0 -
it depends on the size of three things,
1) the steam load
2)the new addition hot water heat load
3)the boiler size
check here for more info...
http://www.heatinghelp.com/newsletter.cfm?Id=29
Noel0 -
tankless heater
i ran a large addation off a steam boiler using a 3/4" tankless and it worked great. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
The water running through the system is usually only 80-90 degrees or so. Did you need some sort of heat exchanger or mixing system to bring the temperature down?
