Oil Burner Recomendation
Ray_4
Ray_4 Member Posts: 1
Hi,
I currently have a 24 yr old very inefficient propane forced hot water furnace, therefore I am looking to convert my house from propane to oil. I am looking for an efficient oil burner and was hoping you folks could help. I was wondering if anyone could share what brands people like for efficiency and reliability and if possible about how much that model may cost.
Thanks for your help!
Ray
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    Oil burner
    Use the "Find A Contractor" feature above to contact someone in your local area to look at your particular job and give you a quote. You will gain efficiency by converting to oil, not to mention being safer. You also might want to pose your question on www.OILTECHTALK.com Good luck!
  • jim f
    jim f Member Posts: 182
    i would recommend burnahm oil fired boilers. i have been installing them for years and haven't had any problems. oil burners vary on efficencies, (beckett-carlin-reilo)
    as of pricing i would recomend going to "find a contractor" and find qualified contractor
    jim franze
    tri-city heating and cooling
    milford,ct.
  • Big Ed
    Big Ed Member Posts: 1,117
    ThermalPride
    I'am not in favor of Warm air heat but if someone asked me what oil furnace I would recommend it would be only one , ThemalPride furnace with a Riello oil burner....Built to last with the newer hi temperature burners ... And yes you will pay more for a ThermalPride... A added note , A Low-boy design seems to last longer then a High-boy ..
    "I am a poor man I could only aford the best "
  • Rob_7
    Rob_7 Member Posts: 12
    I love it!
    What Big Ed said, "I'm a poor man, I can only afford the best."
    That's pretty true!
    Love that saying.
    Sometimes I think where I work must be, so rich they can afford to squander $$$ on cheapness.
    Gets 'em every time...I mean EVERY time! haha
