How to clean fins on baseboard H/W heat?
Patchogue Phil_5
Member Posts: 9
I use a long thin air nozzle ( 1/8th inch curved tube ) from my compressor, which fits between the fins. While using short air blasts, I have the shop vac hose right on the area I am cleaning. The vac sucks up 98% of what gets dislodged.
Fin Cleaning
I don't think my baseboard fins have been cleaned since the sixties.
I swept and vacuumed them out and in the kitchen I flooded them with water to get the dirt out from between the fins and it worked great.
Now I have no idea how to get the living room and dining room as clean (carpeted).
Does anyone have a suggestion other than pulling the carpet out?
Thanks alot
PAT0 -
i use
compressed air on a windy day, with the windows all open. but yo will still have to clean your whole house. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
If you don't have an air commpressor....
You could purchase a small compressed air tank at a home improvement store and refill it as many times as you need at the gas station. Cleaning those fins is definitely worth it....if they were rather dirty, you'll see a drop in fuel usage. While your at it, clean the fins of the refrigerator. These should be cleaned at least once a year. Cleaning them will cut your electrical usage and extend the life of the frig.
Boilerpro0 -
long brisell vac brush....
on my shop vac ,this is what i like to use as well as air,0
