Electronic thermostats
chuck_3
Member Posts: 2
I set the thermostat for hydronic and I will see how it works out over the weekend when I'm home.
electronic programmable thermostat
Since we put in a programmable thermostat on our oil fired hot air system the system seems to run numerous short cycles. I know on the old system this was controlled by the heat anticipator. I can't find a heat anticipator on this new thermostat. Any ideas?0 -
Do you have
A/C, if not do you have a burner control with its own trans former. Who made the Stat? Read the installation instructions paying close attention to the ability to change the unit cycle rate.
Mark
Mark's got it.
Every electronic t-stat I have ever seen has a cycle rate adjustment. Unfortunatly, every thermostat is different in how to adjust it. Check your t-stat install manual, it should tell you how to adjust it. The instructions will probaly elude to a 6 cycle per hour setting for forced air heating, which is bologna in my opinion. Set it for 3 to 4 cycle per hour and you will be fine. If you tell me which stat you have I may be able to tell you how to adjust it. If your t-stat for some reason does not show a way to adjust the cycle rate, then replace it wtiht a better one.
Glenn Harrison, Residential Service Tech
Althoff Industries Inc. Mechanical and Electrical Services
Crystal Lake, Illinois
Althoff Industries website0
- 167 Indoor-Air Quality
