Bad dip tube
Irene
Irene Member Posts: 22
I just found out from an old consumer magazine that my hot water heater has a defective dip tube. Not one plumber over the past 5 years even suggested this even after I told them that my hot water faucets always seemed to be clogged with little pieces of white plastic and I didn't seem to have much hot water anymore. So of course I have missed the deadline to get it replaced by A.O. Smith. Why would the original plumber who installed it not sent tme a notice of the recall and/or settlement. Do you as plumbing contractors get those from the companies? Anyway my question really is, is it worth replacing this dip tube or is this the time I should just get a new heater?
  • eric_2
    eric_2 Member Posts: 148
    How old
    is your heater and do you know the model #? Typically you get a 6 year warranty on standard water heaters or they upgrade to a 10-12 year warranty.
  • Terry
    Terry Member Posts: 186
    flush
    whether you replace the heater or the diptube. make sure you flush the lines/tank with the aerators removed to get rid of any residual plastic left in the system/tank
    Good Luck.
    Terry
  • Mark A. Custis
    Mark A. Custis Member Posts: 247
    We don't get much
    in the way of notification unless one is a stocking dealer.
    This one was everywhere, shame on your servicing contractors.
    The dip tube is cheap enough, its the labor that will get you.
    Good luck,
    Mark
