Bad dip tube
Irene
Member Posts: 22
I just found out from an old consumer magazine that my hot water heater has a defective dip tube. Not one plumber over the past 5 years even suggested this even after I told them that my hot water faucets always seemed to be clogged with little pieces of white plastic and I didn't seem to have much hot water anymore. So of course I have missed the deadline to get it replaced by A.O. Smith. Why would the original plumber who installed it not sent tme a notice of the recall and/or settlement. Do you as plumbing contractors get those from the companies? Anyway my question really is, is it worth replacing this dip tube or is this the time I should just get a new heater?
How old
is your heater and do you know the model #? Typically you get a 6 year warranty on standard water heaters or they upgrade to a 10-12 year warranty.0 -
flush
whether you replace the heater or the diptube. make sure you flush the lines/tank with the aerators removed to get rid of any residual plastic left in the system/tank
Good Luck.
Terry
We don't get much
in the way of notification unless one is a stocking dealer.
This one was everywhere, shame on your servicing contractors.
The dip tube is cheap enough, its the labor that will get you.
Good luck,
Mark
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
