Old base board
Jon S.
Jon S. Member Posts: 43
I’m going to be replacing a section of old cast baseboard. It’s attached to a mono flow system. The tapping on the tees for the baseboard is ½ inch. Can I use ¾ inch fin baseboard with a reducer, or will that cause flow problems?
Thanks,
Jon S.
  • Big Ed_2
    Big Ed_2 Member Posts: 18
    Measurement
    Jon , how much is * ?
  • Jon S.
    sorry
    It must not be showing up as a fraction, The tees are 1/2 inch and i want to use 3/4 inch.
  • Big Ed_2
    Monoflow
    No flow problem with 1/2" risers feeding 3/4" baseboard. But most monoflow-flow problems are the cause of improper spaced tees, lack of a second veturi and air traps.....
