Gas Boiler choices
Dave H_2
Member Posts: 556
OK, New scenario and opinions wanted:
As most of us in the heating industry, we are always working on our own systems. Never finished, just a tweak here and a tweak there. Also never enough time to devote to finishing in one shot.
Home has existing forced air heat and I need to update!
My dilemma is this; I am installing radiant underfloor on the first floor in the next couple of weeks (and finish). Then next year (hopefully) install panel rads like Runtal or Buderus on the second floor with some radiant in the baths. Kinda hard to plan, the family is just growing like mad.
So I need 135 for the radiant on the first floor, 110 for the baths on the second floor, and a max of 180 degrees F for the panel rads.
Since this project may take a while, the big choice I need to make is boiler choice. Phase one of the first floor has a heat loss of 15,000 BTUs, Second phase brings the load to 25,000 and with the addition of the second floor, total load will be around 50,000 BTUs.
I would love to install a heat source that would be able to match all of the loads, say with a modulating gas boiler. A couple of names have been thrown around but I would like to see what others (if any) choices there are.
Thanks in advance
Dave H.
Thanks in advance
Dave H.
Dave H
Everyone here will have
their favorite. The water temps are easy with the proper mixing valves etc. Do your heat loss
their favorite. The water temps are easy with the proper mixing valves etc. Don't make my mistake and not include DHW. My favorite boiler is one that is properly installed so it works.
Good Luck,
Mark
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
