High temp Hot water
Jim_47
Member Posts: 244
Hello, here I am with another need of the intense inteligence of the members of the wall community.
I am covering maintenance for an industrial application. They buy hot water from a central hot water supply boiler plant. Here is my question:
The water is 375 degrees F at 275psi. There is a flow indicator on the main line coming into the boiler room that indicates 245gpm flow. The return water is varying from 230degrees to 275 degrees F. So I am seeing a temperature drop of approximately 100 - 140 degrees F. Is there anyone here that can help me determine the BTU consumption of this boiler room? Or show me to a source that I could go to find the formula(s) needed for this calculation?
AS always thanks
BTW lots of "dead man" sized pipes in this boiler room.
AS always thanks
the formula comes from this one...
BTUH / (8.3 x 60 x TD) = GPM
flipped around, I think it reads
BTUH = 8.3 x 60 x TD x GPM
BTUH = 498 x 100 x 245
to 498 x 140 x 245
or 12,201,000 to 17,081,400 BTUH
Sound right?
Noel0 -
call ED @ ISTEC CORP.they sell btu meters , recorders ,etc. tel# 1 908 241 8880 fax#1 908 241 72880
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
