Normally open zone valves?
John Abbott
Member Posts: 361
I would appreciate any input on a reliable brand/model of normally open zone valves for a project I am working on.There will be multiple zones 10+ and multi temp injection with constant circulation on all of the high mass zones. I am partial to the Taco heat motor type for normally closed applications due to their simplicitly and reliability over the 20 plus years I have used them,but I understand that their new ESP valves are troublesome to say the least.
Thanks,
John0 -
Check out the White Rodgers 1361-102, they have a clever warp switch in them so the motor is only under load when the valve is opening or closing, the majority of the time the motor is at "rest". They also have some big time cv (23.5 for the 3/4" and 37 for the 1" valve). We have used hundreds of these valves, switched to them after the Honeywell/Syncron motor disaster of the mid-90's. The wiring is a little funky but we made our own diagrams and all is well with the Sparkies. pj
p.s. their address is white-rodgers.com0 -
Invensys (Erie) has normally open valves
Just started using thier valves, I've heard good things about them. Also can vouch for the White Rodgers, see many with 20 to 30 years of service....as long they are made like they used too.
Boilerpro0 -
N.O. zone valves
I've used a couple hundred of the honeywell "VC" zone valve, and so far have had no problems. Its only been a couple years, so we'll see.
I like them. They can be either no or nc, and are powered both open and closed.
Steve
I hae used -
both Honeywell and Erie with good success - but it depends on application. I have found that Honeywells do not like to be on the supply side of radiation while the Erie seem to like it - just an observation - but the Honeywells hammer like crazy if not put on the return side. Anyone else notice this ???0 -
water hammer?
No I have not had the water hammer problem on the supply side.
Steve0 -
hammer
only seen this when valve in backwards. the V8043 series tend to leak past if press diff too stiff.
Terry
Thanks
Thanks...
to everyone for their help. It is much appreciated.
John0 -
Zone valves
There is only one for me and that's "Automag" Check them out. We have used several hundred with no problems. I don't have their # on me but I can get it for you if you need it. Just e-mail me. It's small, simple and they work. They come with 2 lights so you know what is going on and they are NO.0 -
Yes
Yes I have, never have problem on return side. Dan brought this to my attention at one of his seminars.0 -
I'm with Troy
I have to go with Troys choice for the "Automag" I used them while I was in the field for over 10 yrs with noting but success!
Your friend in the industry,
Alan R. Mercurio
Oil Tech Talk0 -
Hey Ken...
I got your inquiry and responded but it came back as undeliverable.Send me your adress and I'll try again
John0
