Unbelivable!!!!!
bovide_2
bovide_2 Member Posts: 6
maybe u shud uze schpelchech so u wud not hav so many typos.
  • Ray M_2
    Ray M_2 Member Posts: 64
    Unbelivable!!!!!
    I just finished a heat load /ac load off a set of plans.
    3 contractors did the same.The builder is having a fit,who do i belive he asks me? I faxed him my sheets using the new wrightsoft manual J 8. My heat loss findings are about half of the others and two thirds less on cooling. I asked what software they were using he said he got a quote not a heat loss/gain sheet.
    Unbelivable
    Ray M
  • heatboy
    heatboy Member Posts: 1,468
    Does that mean......
    you get the project? Did he pay for your effort?
    hb
  • steve_6
    steve_6 Member Posts: 243
    heat calcs.
    Does that suprise you? pretend your in the market for a new furnace or boiler. Call and get yourself a bunch of estimates and recomendations. I'll bet that if you had a dozen heating contractors come in, less than half would do heatloss calculations.
  • steve_6
    builders are
    notoriously cheap. I'm not saying all are. But if your the sub that can provide what he thinks he needs, the low bid is going to get the job. Thats why scorched air usually comes out ahead with them.
  • harvey
    harvey Member Posts: 153
    I have found builder's naturally go to the bottom line. They need to be educated in how to qualify a bid. I always ask to see the other guys calculations and of course they don't have any. Our work is different from other trades as rarely there are codes that cover capacity or sizing.
  • Ray M_2
    Yes Heatboy
    I got the job based on doing the right thing.I see alot of homes that are a mess as far as the mechanicals.The kitchens aand baths are great,so they didnt notice the 80%furnace and over sized condensor outside.
    Thanks
    Ray m
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    GC'S
    Builders want the low price so they can tack their markup onto your number, in some cases making more money than the guy doing the work. And guess who has to warranty the system. Very hard to find a good builder to work with. I am absolutely not saying that all builders are crooks, but typically that is high output work with low income dollars in new construction. If you work with a good builder, then keep a good relationship because that is the exception rather than the rule. There are lots of companies lining up to do the cheapest work, letum have it. Concentrate on dealing directly with the homeowner. It is much more effective to directly educate the end user and customize directly to their needs, rather than bow to the GC,s socalled budget number.
  • KING GEORGE
    KING GEORGE Member Posts: 2
    hey pal
    i have relitives that resemble those remarks. these people do very good work and how many houses you see falling over. compared to heeting systems breaking down. comfort tech indeed. and people wood pay for better stuff if you kwit ripping them off and besides with all them fancvy tools you not have to work very hard any ways.
  • paul lessard_3
    paul lessard_3 Member Posts: 186
    royal a ol
    are you a builder? are you o.k ? anyway my fancvy heeting siztoms hardelly neeever kwit workieing
