NYS law on DHW and tempering valves.
Mad Dog
Member Posts: 2,595
safest bet mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=210&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
I have been told that it is the law in the state of new york that on all direct fired water heaters,indirect and tankless coils you must install a tempering valve.Is
this true,I have not been able to get a straight answer.Personally I have been installing them for past couple of years but two boiler inspectors in nyc one said I had to and one said no.Can anyone tell me the law please.Thanks in advance0 -
Why wouldn't you?0 -
The code-NYS
Joe, I went to my local inspector's office and read the codebook myself. The only thing we saw was that a Water Heater used for COMBINATION heat and hot water(like the Bock system or heatpump helpers) must have one. I guess they assume that you would have 180 degrees for heating. That is all I saw after about 30 minutes of searching the different books. So, I would say no. But, that said, I think it would be a good thing to put on anyway.0 -
use thermostatic mixing valves
i use sparco and they deliver a more even water temp. and a safe high water temp. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Hot water temperature.
You need to make sure that the hot water to a faucet does not exceed 125 degrees and a constant supply of no less than 115 degrees is met.
Any system that produces hot water by steam or emersion in a boiler or other device should hasve a mixing or tempering valve.
If a person gets scalded and you are the contractor that did not provide for the control of the hot water you will learn a new game of tag. Its called tag your it.0
