New Home in Oregon
jim_15
Member Posts: 6
No I haven't. But I will now.
Thanks Dan.
And thanks to whoever referred Scott Duehn at Specification Sales in Vancouver. I'll be talking with him too.
Thanks, all. I'll let you know how it turns out.
- Jim
Thanks Dan.
- Jim
Finding a Contractor
Can anyone here recommend a contractor in the vicinity of Portland, Oregon who can design and install a heating & cooling system for my new house?
Having seen, and lived with, many different kinds of heating systems, Ive decided that I want a radiant hydronic system *and* air conditioning in this house. I understand the challenges involved in such a system, especially since the floor finishes are to vary widely. The basement will have a partial concrete floor, and a partial plywood floor on sleepers finished with linoleum. First floor will be hardwood (T&G, not laminate.) and the second floor will be padded & carpeted. I understand the difficulty that this poses to the person designing the heating & cooling system, so I want to get an HVAC contractor onboard early, before the designs are complete. My thought is to use an oil boiler for heating and a Unico or Space pak cooling system, but Im smart enough to go with whatever my contractor recommends.
Heres my predicament: I cant find a contractor.
Ive called five so far. All recommended by other local heating guys who dont do hydronic work. After describing my project, herere theyre responses:
Contractor one: We put radiant on the first floor and heat the second floor with forced air. Its easier that way.
Contractor two: We just do what Radiantec tells us.
Contractor three: If you really want to heat with water, you should use a hyro-air system, its the best of both worlds.
Contractor four: Hydronic? Really? Wow. Ive always wanted to do one of those.
Contractor five: I dont know . . . radiant heatings really expensive. Are you sure you want to go that route?
Anyone have any suggestions?
Anyone have any other advice for me at this stage of my home-planning?
BTW, I probably shouldnt mention specific pricing on this board, but Im planning on budgeting about twice the cost of a top-of-the-line heat pump. Is this reasonable?
Jim
Have you talked to
Larry & Chuck's Heating in Portland? (503)232-5747Retired and loving it.0
- 167 Indoor-Air Quality
